- Year
- 1991
- Vehicle Model
- 70 Series
- Location
- United States
- Mileage
- 100901
- Color
- Yellow
It's a sad day. I need to sell our 1991 Toyota Land Cruiser HZJ77. We recently purchased a home over on the Western Slope of Colorado and we've inherited a few more problems with it than we expected. It needs all new plumbing and some slab leveling work. Long story short the Land Cruiser needs to go so we can do these home repairs. It's an incredible truck. I purchased it from a fellow i8Hmud member. It's well documented and much loved. Since my ownership I've done a fair amount of work on it. Just recently I replaced all front end suspension/sway bar bushings. The truck has just over 100,901 miles 162,385 KM on it and runs like a top. The 4x4 both high and low work perfectly. Automatic shifts great. Almost brand new Toyo Open Country MT tires on it. The roof rack is bomber and ready for a roof top tent with custom cross bars. I also have a full length awning for it. It starts up great, even in these cold desert winter mornings. I just let it idle for a bit before taking off. The diesel injection pump has been adjusted and it's pretty much eliminated any black smoke on hard acceleration. I installed an EGT gauge in an OEM opening in the dash to easily monitor. I recently imported the OEM rear tire carrier from Saudi Arabia and installed it in the OEM mounted holes. The body and frame are in great shape. The previous owner loved this truck also, he did a bunch of mechanical work on it while he owned it. Items are listed below.
Recent Services: All service done using genuine Toyota Parts I bought either from Cruiser Outfitters (UT) or Valley Cruisers (CA) or local Toyota Dealer. 2020 water pump, timing belt and associated oil seals, New upper and lower radiator hoses, Coolant Flush, new thermostat and seal, valve cover gasket, intake plenum gasket, fuel filter, Full front end knuckle rebuild ( all seals, wipers and bearings) , front diff. fluid. 2019 Hydraulic Oil changed in front and rear diffs, transfer case, PTO box, Oil and Filter Change, Brand New Toyo Open Country Tires. 2017-2018 (based on info from previous owner) Two brand new Optima Batteries (720 CCA each), electric front hubs replaced with more reliable Aisin mechanical units, front brake pads, rotors, calipers, rear pads and rotors.
As for known issues they are described below.
Known issues: Front passenger window switch ( in the driver side cluster ) only works in the "down" position, the passenger side switch works perfectly, small crack in the dash pad, Rust areas are: 1" surface bubbling area by the sunroof, small cavity under the side step, under right rear door, around the skirt drain hole and a 1" spot on the rear diver side wheel arch, where the rubber bumper moulding is attached.
I've attached a few photos of the Cruiser below. Mostly glamour shots. I can take many more photos if you need. I just wanted to get it listed ASAP due to these needed home repairs. Please feel free to message me with any questions. I'm located in Grand Junction, CO right by the Colorado National Monument. Thanks!
-Tyler
Asking price is $19,500
-Tyler
