What RPM should my 96 be at when started cold? It jumps to about 1800 (I can hear unlubed valves) then drops to 1500 until I put in gear. It seems too high.
Hey Dan I am intrigued about your post... can you elaborate? So does ECM check for IAC position and how it does that?How many times have you cycled the ignition since you did that? The ECM looses it's mind about the IAC setting when the power is interupted. It takes several ignition on-off cycles for it to re-set.
