Cold Start "Buzz" Under the Hood
WV
I've noticed on cold mornings (~0-10 deg F), there is a loud buzzing sound that lasts 1-2 seconds and is emitted from the engine compartment just as the engine is started. I think it is a bearing on the water pump/alternator/AC Comp./PS pump. I've searched this forum & came up dry. Has anyone out there experienced this? I don't know how better to describe the sound. It is a loud buzz....as loud as a horn....but, it is not the horn.
Thanks for any feedback you can give me. :confused:
Oh...I have a '97 FJZ80, 121K, Lockers
Power steering pump.
Normal.
Or A/C idler pulley. Cheap fast fix if so.
DougM
Have the same sound when I start mine cold.......power stearing huh, will give it a look, my wife loves starting the cruiser with my head in the engine bay..not sure why
Dan-
It sure is nice to hear you say that its normal......I've been wondering about that too. Thought it might have been the VC for the fan. Anything one can do to eliminate it? Short of moving where it's warm, of course. TIA
Tony
Damn, I was in WV on the Gauley 4 weekends ago, 0-10 again? I thought it was cold then.
We've had a pre-Winter bout of cold weather. It's not too bad now in the panhandle. We have ~6 inches of snow on the ground; but, temps will be up around 40 today.
Well, I have had this for a couple of mornings now, and it is definately coming from the PS pump.
Does anybody know if doing the fluid exchange with new Mobil 1 ATF (and Downey, of course :D ) will help reduce the noise level?
Plug it in. I was astounded by the number of people who did not know what that sound was. Pretty standard for all vehicles where I come from. Plug in your block heater. This will minimize or eliminate the buzz.
Cheers,
Sean
Cheers,
Sean
Which 80's have a block heater?
The ones that have had them added by the owner.
Thanks. Is this an OEM part or an aftermarket deal?
Available at one time as an over-the-counter option, discontinued several years ago. In the past I have been able to source a few through a vendor that was getting them from the original Canadian manufacturer. That well has also dried up...:frown:
