Grench
Doug,
I must disagree with you in part. The air drawn in from the inner fender is just as hot as what is under the hood. The aprons have big holes in them and air passes freely between the inner fenders and the engine bay. I have measured temps in both locations. I can also tell you that the snorkel moves more air and, at least in my case, the throttle response is noticably "crisper" with the snorkel.
3X
I think I would agree with CDan about the snorkle. If you want power get a supercharger or turbo.
2X
C'mon guys ..he's not asking about a supercharger or a turbo...he is specifically inquiring about an open air filter .....obviously a Turbo or Supercharger will work better...but hmmmmm...thats about 3,000 times the expense of a filter )
airlaird
Open air filter = bad idea. The OEM air filter is built VERY well. Take a close look at it - it is a giant centrifugal pre-cleaner with a tuna can to collect the larger bits AND a washable (available through CDan) pleated filter with a HUGE surface area.
The snorkel is a longer tube BUT it is a straight shot of air from above the dust line and away from the engine heat. Also, the factory air tubes inside the fender constrict down to a bit over 2". It is an intake muffler system with a big surge chamber hanging on it. The snorkel is nearly 4" diameter the entire length.
The top posts in this thread seem to be taking the opinion that the designers of the 80 series could not have possibly known what they're doing. To me, these are the reflex notions of new owners who are used to adding gadgets to small cars to 'add power'.
The reality is, short of forced induction, you're not going to get any better performance out of the intake by putting an open filter in the engine compartment. In fact, you will stand a good chance to do your engine a fair amount of harm.
Anyone who has driven one of these through even slightly deep muddy water (>6") has seen the splash line on the inside of the hood where the fan throws it. I fairly regularly have thin mud thrown up over the air intake box, the top of the engine, etc... These trucks do -not- have a water tight engine compartment. Wet stuff gets thrown up there even in a heavy rain.
Now picture your open filter getting mud, water, etc... thrown all over it. It is going to suck that water through the big holes in that foam filter right into the engine.
The stock inside of the fender intake -is- shielded from this spray. The top of a snorkel is shielded as well, though you might want to spin the top of it backwards if you're driving into a serious rain or snow storm.
These trucks do great in severe weather. The intake was very well designed. Removing all of the protection from the intake is a bad idea all around. It does not add to power (the stock system flows freely), it does not do a better job of filtering, it adds oil to the MAF and can toast it, and it puts exposed air filter material right into the worst place possible - high temperatures AND liquid water.
The only person I've seen here who it makes sense to have a bling exposed air filter is probably LX_TREME - but I doubt if he drives his truck in the rain much if at all. He'd spend the next 2 months cleaning it with toothbrushes and cotton swabs if he did, and change anything he couldn't get the dirt off of. If you live in a desert city (LA, Vegas, etc...) and never go off road, and are really into shinny bling - then it -might- make sense to go to an exposed filter.
