Coil ??
Discussion in '40- & 55-Series Tech' started by Doorguy, Mar 14, 2004.
  1. Doorguy
    Doorguy
    25
    Feb 14, 2004
    My 71 has the original coil and ballest resistor. Can I replace the coil with a newer one and not use the resistor?
  2. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    If you do you will burn up your points. The ballast resistor cuts down the voltage to something less than 12V. I thought it was 6V, but there is some difference of opinion about what exactly is the voltage. Ballast resistors are cheap and they make some that are adjustable.
    GL
    Ed
  3. Romer
    Romer fatherofdaughterofromer Moderator
    10,705
    1,752
    Sep 14, 2003
    Centennial, Colorado
    I think you can if you switch to the Petronix Elec ignition kit. Some one double check me on that.
