Ok... I have wired a toyota EFI system onto an 84 toyota block/head.
I have ran into some problems, some have been fixed... Others not so much.
I immediately pulled codes;
21 - o2
41 - TPS
51 - IDL/TPS
52 - Knock
Engine will start first try and idle strong for ~30 seconds. It will then start running rough and without input, it will die. If you just move the throttle ~1/4" it will smooth out and run perfect. If the TPS is unplugged, it will idle high but run okay otherwise.
Any quick 'blip' of the throttle will result in it dogging. If you don't let off immediately after it dogs, it will backfire through the intake.
So... I went through and adjusted the toyota TPS. I found it had a 'dead' spot in it. Replaced and adjusted per 4crawlers page. Ohms within all Toyota FSM specs.
That got rid of code 41.
I changed the passenger motor mount.
Bye-bye code 52.
I checked, double checked, and triple checked the timing. 5* with terminals shorted.
I thought it may be the AFM. Ohmed out to FSM specs.
I thought it might be a vacuum leak. I took a propane torch and moved it around the intake unlit. No change.
I thought it might be the wiring to the TPS. Wires ohm out to have no resistance.
I thought it might be grounds. I have grounded it so many ways it resembles a motor on life support.
Fuel delivery = great.
I pulled the valve cover and timing chain marks, cylinder, and harmonic balancer marks all check out.
WHAT AM I MISSING?!! Pulling my hair out!
21 - o2
41 - TPS
51 - IDL/TPS
52 - Knock
Bye-bye code 52.
