OK, I have been searching this all afternoon and come up with a few things to start looking at but thought I would throw this out there since I haven't seen this particular problem posted. Truck is a 93 w/ ABS, 235,000 miles.
Had 2 times over the last few days where the truck died when I came off the throttle. Both were driving up a hill and stopping at a gate.
Noticed that the idle seemed a little low at around 500rpm.
Today I got a CEL code 25. It was on for a bit them went back off.
While going over the truck and looking and listening. I noticed something weird. When I have the truck in the driveway in park, if I slowly rev the engine I am getting a misfire at 2200rpm. Once I hit 2200, it drops for a second to 1400 then back to 2200. It bounces like that a few times before the RPMs go beyond 2200.
I was initially thinking O2 sensors and maybe the PAIR Valve but the misfire at the specific RMP has me thinking otherwise. Troubleshooting in the FSM is showing the following are common suspect areas for the misfire and engine stall after accel pedal release.
EGR System
ECM
Volume Air Flow (VAF) curcuit
Only thing that cross references to the Code 25 is the VAF.
Going to test the VAF and see what it does.
Any other ideas?
EGR System
ECM
Any other ideas?
