Co2
Los Angeles, CA
Website
www.phipsi.net
I Thought CO2 had to be mounted vertically and that it wouldn't work on its side(horizontally). In looking at a few mounting options for CO2 off the search functiona powertank setup shows the tank on it's slide....am I wrong or is the side mounted tank removed and used while vertical?
-Sam-
I can't see any reason why it wouldn't work. I would recommend you call a welding supply shop, they should be able to give you a pat answer.
I've seen them mounted both vertically and horizontally. Horizontally when stored -- never seen one used on its side.
CO2 tanks can be stored horizontal or vertical or upside down. To use, they should be vertical or at least 30 degrees from horizontal with the valve raised. The reason is that CO2 in the tank is liquid and as it evaporates it becomes a gas. The gas rises to the top of the cylinder and what you want for filling tyres is the pressurized gas, not the liquid CO2 (unless you're using it as a fire extinguiser.)
-B-
It even says right on the powertank website that it is ok to store horizontal but to use it must be vertical. ... moving this to outfitting.
and you need a special regulator for CO2 also, can't use those for inert gas, air etc, I read someplace.
It would spray liquid CO2 if you used it on it's side but people store them that way for convienence, including me.
On the valve note, Desertdude has a really nice adj. regulator w/ liquid filled meter on it. I wanted an adj. one anyway and that is the ticket for me.
Right now I have the standard fixed 150psi regulator which is perfect for airing up tires.
-B-
Not 100% correct, I think the correct number is 32.57 degrees.
Also, if you try and use CO2 with the tank horizontal, the valve will freeze very quickly.
I have mine mounted horizontal in my bed tool box, along with a dual battery set up, tools and supplies. I can lock the box and keep all the goods hidden out of sight ;)
James - I was using my tank with a finish nail gun yesterday to install basboard trim in my house. The adj gauge came in handy, plus the tank makes no noise compared to a compressor. I can hear the XM radio now while I work :)
I've used mine on its side several times. I've never had any issues for airing up tires. However, it does seem to go through more C02 when horizontal. I've never had a liquid problem. Maybe I've been lucky? It isn't something I really tried to do. It just happens that sometimes I'm too lazy to rearrange everything to undo the straps.
well, if you somehow got liquid CO2 in your tires, that would get interesting very quickly...
not likely I imagine as it would boil right away in the hose, but the pressures could get weird
CO2 on it's side is bad, vertical or as close to vertical is best. And to ginericfj80, you did have the liquid problem..that's why it seemed to use up more because the liquid didn't expand into the gas so you lost some of your fill inefficiently.
I've read and heard (but not tested this) that a problem with having the liquid CO2 entering the tire is that when it goes gas, it can expand rapidly and potentially cause said tire to fail explosively.
Ouchy!
Ouchy!
That's right.
Using the tanks horizontally, other than for transport or storage, can be extremely dangerous. Also filling tires from a horizontal tank could kill you.
Read the cautions on the websites of CO2 system sellers - if you don't you're being really stupid.
ginericfj80 said:
I've used mine on its side several times. [ ... ] Maybe I've been lucky?
You have been lucky and probably had a partially full tank. Anything below half full would likely have the valve above the liquid CO2 depending on how level your truck was sitting at the time.
As others have mentioned to you, it would be very dangerous because the liquid CO2 could get into the tyre. More likely would be that your valve, regulator, and hose would either freeze or clog. Our regulators are not designed to pass the liquid CO2 like a CO2 fire extinguisher.
-B-
Honestly, I've stuck with compressed air. I have a 100cf Steel tank @3500PSI. Now that is a bit expensive, I also dive so thats the reason for the size and steel of the tank. But you can mount it any way and the pressure difference (in tank capabilities) isn't that different (a little in favor of air).
Also, I'm not sure how many manufacturers do this but you can get a syphon tube that goes to the bottom of the tank (or a short one that just goes up) and depending on the location you can have it mounted a couple degrees off horizontal. Of course you'd have to ensure the tube is always facing up : )
