Wanted CO - Looking for low mileage FZJ80 with diff lock (2 Viewers)
Year
1997
  1. 80 Series
Long shot here, but figured I would see what turns up...
Preferences:
1996-97. Would consider other years.
Any color except beige metallic or desert dune.
Less than 150k miles. No accidents.
Minimal or no rust.
Cloth interior is best. Prefer no beige interior, but would be ok with anniversary trim in good condition.
Light mods ok, but I'd prefer stock with good maintenance history.
In or near Colorado is best, but could fly and drive.
If you are thinking of selling, let me know!
It has been fun lurking and learning from you all. Thanks IH8MUD folks!
I have a 97 lx450 all stock 3Xlock with 154xxx original miles located in San Jose CA
I'm working on getting ready to sell my 97 Lexus LX450 with great bones and lots of work done. I just don't have all the pics and details yet, but let me know if you're serious. See images and description below.
1997 FJ80 Lexus LX450 Triple Locked Toyota Landcruiser
$20k. Don’t waste time with unrealistic offers
Engine 237K miles
New Radiator
Wits End Blue Fan Clutch upgrade
Ford Facing 90 degree oil filter adapter (M-6880-A50) Banjo bolt deburred & chamfered
New A/C Condenser, Accumulator, Evaporator core (A/C is ice cold)
Head gasket replaced by previous owner
Wits End Oil Pump Leak kit (not installed yet)
Dual OEM cats removed and single Magnaflow cat installed for clearance
Driven every week or two and kept in garage
No oil drips when driven daily, let it sit a week or longer and small dime sized drip
Drivetrain less than 6000 miles on all components listed below
Front and rear axles fully rebuilt with new bearings, seals and fluids
Birfields cleaned, inspected and repacked with Red Line CV grease
Cruiser Outfitters Birfield knuckles rebuilt with all new felts, seals, rings
Front and rear brakes have new calipers, rotors, rear load sensing proportioning valve
Front and rear pads are Powerstop Evolution Ceramic Z-17 series
Replaced all questionable wheel studs and have spares studs and extractor tool
All wheel lug nuts are flanged stye for factory wheels
4:56 gear third members from East Coast Gear
New OEM Aisin E-Lockers assembly front and rear (still have originals)
Suspension
Old Man Emu Stock height full suspension kit +.75” lift with front 20mm spacers
OME springs, shocks, steering stabilizer
OME Caster Correction Bushing and tool (not installed)
LT285/75R16 - 32.8” Falken Wildpeak AT3W (less than 5000 miles)
Exterior
Wits End Floppy Mirror fix driver & passenger sides, both power mirrors work
Front bumper Rigid LED Daytime Running Lights (high, low, off function)
OEM roof rack removed to inspect for rusted nut zerts, all are OK
Have all components and hardware to reinstall roof rack
OEM running boards removed and front OEM mud flaps installed
Spare tire leveling kit installed but not used, interior tire carrier holds spare tire
Paint in decent to good condition, clear coat on roof and PS fender need attention
Pics will show all areas that are not like factory paint
Clear coat pulled from tape around Rigid DRL’s
Passenger rear plastic bumper corner kissed by parking lot driver
No rust on body panel, underneath, or drain holes
Frame has only surface rust on factory welds and bolt heads
Front inner fender mounts have rust at single bolt mount (both sides)
Interior
All power windows and sunroof fully operational
Front power seat Gamivi full gear sets and screw replaced and all fully functional
New leather wrapped steering wheel and shifter handle
Wits End Useless Ashtray Switchplate with Ram X Mount for phone
All interior doors sprayed inside with sound deadener
Front driver and passenger new power window motors
Rear floor and cubbys have sound deadening matt installed
Rear third row seats with like new leather, one seat removed and goes with sale
Second row seats very good leather with no tears
Driver and passenger seats reupholstered with vinyl by the previous owner :-(
Front, Rear and Cargo area WeatherTech floor mats
Carpet is good/decent but has some improper cleaning spots
Kenwood 7” radio with Apple Carplay & Android Auto
Head unit Hands Free microphone hidden above mirror
Back Up camera with parking lines, OEM look and mounting
Pioneer 6.5” door speakers with color matched grills and 6” amplified Bazooka tube
Broken power antenna removed and new fixed mast antenna installed
Interior tire rack has mount bracket for CO2 10lb or 15lb PowerTank
PowerTank bracket doubles as Bazooka tube mount (single connector removal for CO2)
Original owners manual and binder & original Lexus Emergency kit
One OEM door remote and alarm key fob
Miscellaneous
OEM service manual, 54mm front Axle nut socket tool, fabricated dust cap driver tool
Spare wheel studs, spare OEM lug nuts,wheel stud removal tool, 2 original speaker grills
2 spare wheel Center Caps, Ultragauge Scan tool (not mounted, couldn't decide where)
Valve cover gasket, Intake gaskets, PCV valve all new in box
Axle rebuild kit extra hardware (flanged nuts, studs, Birf rings….)
Any original parts removed or replaced if not damaged
