- Location
- United States
completely cleaned fj62 axle. perches have been cut off, ready to weld on your spring over stuff. has factory truss. comes with knuckles, spindles, backing plates, rotors, hubs, aisan lockouts, new 4xlabs frombe steering arms, axle shafts, birfields, rebuilt calipers. diff with arb locker and stock gears (most likely needs new oring). parts are all cleaned up ready for assembly (except for surface rust on the rotors from sitting on the shelf for years)
front axle sold, so now parting out
disc brake conversion minus steering arms (knuckles, spindles, hub bodies and dials, used spindle nuts, lower knuckle caps, backing plates with air scoop, used rotors, rebuilt calipers, used birfs) $350 (just hubs $50 each)
new 4x4 labs frombe steering arms with new ricebilt rods (for fj60 axles in a 40/55) and 4 new oem toyota fj80 ends $500 (just arms =$300, just rods =$70 ea or 120 for both, just the ends $35 each)
oem knuckle rebuild parts (all bearings and gaskets) $200
fj60 birfields and shafts $ 85 for the long side, $65 for short or $125 for both ($50 each for just birfields)
also have a spare set of fj60 inners $40 for long, $20 for short
2- cryo treated birfs $80 each
diff with arb locker SOLD most likely needs new oring as it's been sitting for years.
