Clutch/tranny noise?
Grand Rapids, MI
I've just (no noise the day before) developed a squeak in my driveline that is directly related to rpm not speed. High piched squeak that goes away if I rest my foot on the clutch pedal. I've adjusted the clutch pedal play and that hasn't helped unless I adjust it really tight then it goes away. What is this sound and is this a problem or just a nusiance? Everything else seems fine. Shifts great, no noise with clutch depressed, everything feels real smooth. Looking for a solution short seperating the engine and tranny to do clutch work. Stock 60 with 4spd. How tight can I adjust the clutch without causing harm?
Unfortunately, it sounds like the throwout bearing is getting noisy - no easy way to fix it. It might get worse, or it might stop squeaking all by itself.
A throw out tends to make more noise when the clutch pedal is depressed (when the bearing is loaded up) right? It could be the T/O just started to go bad or it could also be the pilot bearing (?) Unfortunately, that doesn't make the fix any easier.
EDIT: but definitely check the fluid first! Start with the easy fix and work your way down the list.
I'm going to check the fluid today and cross my fingers that sloves it. I've heard the noise from a bad to before, but it was a little more grinding sounding and only made noise while the clutch was depressed. Just the opposite of mine.
I did climb under her yesterday and wiggled the clutch arm that goes to the TO. Noise was gone for a couple of pedal depressions then came back.
Well the tranny was a little low so I went ahead and changed the fluid. Didn't help. Curious thing is the PO had put ATF fluid in the tranny instead of the Hypod oil. Doesn't seem to have hurt anything. Anyway after removing the inspection cover from the clutch/flywheel area I was able to track the noise to the TO bearing. Going to get some white lithium grease with a nozzle and see if I can shoot some grease in the bearing. If that doesn't work I just wait for it to get worse or go away by itself. Thanks for everyones help.
thread revival
Just wondering how you got the grease into the T/O bearing. Where did you squirt it? I'm having the same noise. Wierd since I just replaced the whole assembly.
be careful not to adjust your clutch pedal too tight; you'll risk wearing out your clutch prematurely.
as per the FSM, the clutch pedal should have between 13mm-23mm free play.
Thanks. I loosened up the release cylinder a little yesterday and the noise went away.
