First time doing a clutch and I've hit a bit of a wall. The service manual isn't too clear about what to do after the cross member has been removed and the transmission is jacked up....
This thread How to change a clutch step by step with pictures + descriptions says, "17. Unbolt the cover under the bell housing (5 bolts)". Looks like my cover only has two bolts. Then it says to remove the four bolts that hold the transmission on.
I've read a few older threads, but I can't seem to find a clear answer on whether or not I need to remove the bell housing before I remove the tranny. Can I pull the tranny first, then remove the bell housing to get at the clutch?
Thanks.
Thanks.
