have some one press the clutch in ( not running ) while you look at your slave, see if it is even moving the clutch fork.
did the slave rod push the clutch fork?
I would start there.
The slave rod pushes the clutch fork ( the metal bit coming out of your bell housing with the rubber boot around it ). The clutch fork is on a pivot, and cantelevors / pushes the pressure plate in so you can disengage the clutch tochange gears.
How far does the the slave rod push the clutch fork?
No inspection cover is gonna make it pretty tough to see what's happening with your clutch.
there is no clutch inspection plate at all on your bell-housing.?
Thing is, if the clutch fork is pulled away from the pressure plate ( towards your spring and slave rod )
your clutch should be engaged, assuming your in neutral.
can you verify your truck is in neutral?> ( follow your shift linkages )
you said it lurched when you started it in neutral? or was it stuck in gear?
can you post a photo of your clutch inspection plate, or the bottom of the bell housing, between the oil pan and the transmission >/?
it is likely that you need to rebuild you slave and master and bleed it, as you slave is leaking.
But it be nice to be able to see what your clutch arm is adjusted... ie how far your clutch or is pressing in your pressure plate
Is a flare nut wrench required to loosen the nut at the end of the black hose?
cbmontgo said:The truck would lurch when the key was turned and the clutch was depressed, so it was essentially not working. It is now in neutral and will start and idle fine.
I picked up the new part from Toyota today, but they ordered the wrong one. The bolts are spaced differently and the body is a little different. It sucks because these are 2 days out; really needed the part today.
No. An open end wrench will do. I doubt that a flare nut wrench would get over the rubber line.
That spring costs $3-4 from Toyota. It will probably fail before your new slave. I'd replace it now while you are under there.
Good to know. I will just use an open end wrench then.
Crap...forgot to order that today. The new cylinder comes in tomorrow from Kansas City. Will have to grab it next time I am over at Toyota.
Blue looks like Aisin. Is your dealer trying to pass off Aisin as Toyota?
A blue slave cylinder from Toyota?
That is a new one for me. EVERYTHING hydraulic I have ever received from them in 24 years has been black.
