1969 FJ40
1.5F engine
Original 3 speed (3 on the tree) gear box.
98,000 miles ( or 198,000 miles, its hard to tell)
So my '69 FJ is parked in the garage currently. Last time it drove i noticed some difficulty shifting, a little more grinding between gears than normal. by the time i got it home, i wasnt able to shift with the engine running. I am able to shift through all the gears when the engine is off though.
My first thought was my master or slave cylinder. After replacing both cylinders and the hydraulic line there is no improvement. I can see the clutch fork moving when the pedal is depressed, but the gears still grind horribly when the engine is running. Currently its impossible to shift into any gear when idling. Did I blow something up? throwout / pilot bearing?
Im seeking help diagnosing this issue before i have to bring the gearbox out of the truck. if I can repair it reasonably, i will. If not ill look into replacing my 3 speed with a 4 speed, or possibly something with overdrive.
thanks,
-P
1.5F engine
thanks,
-P
