There are probably threads, you may just need to be persistent in searching because they might not use the key words that you are searching with.
If you have installed it and bled it, then I hope my question will be clear (even if I communicate poorly).
Did you measure the length of the original rod connecting the pedal to the clutch master? After measuring, did you then adjust the length of the same rod with the new clutch master to have this length?
If the length of the rod with the new master is off (probably short), then the pedal stroke might not be enough to fully stroke the slave cylinder and lead to shifting difficulty. Just a thought ...
