Discovered my Clutch Master leaking a few days ago and caught it before too much paint melted away on the wall/floor. Pulled the clutch pedal assembly, replacing worn parts and installing a new master. As usual, I’m confused again
The clutch and brake pedals looked more or less the same distance off the floor before I pulled the old stuff, but the clutch pedal was not touching the stop.
If I pull the pedal to the stop (I’ve left where it was) – the pedal distance to the floor looks like it falls in the proper 8.5-inch range. But in this position the clutch pedal is notably higher than the brake pedal. Anyway, I’ve left the stop where it was.
The play at the “ball end” (master housing) of the rod seems built-in?
Is the idea here to:
1) Set the pedal stop
2) Turn the push rod to lengthen it until there’s only .02 – .12 inch play in the rod?
3) In that case, where does the “Free Play” .8–1.6 inch come in (see lower manual page)?
I was hoping to adjust only at the pedal, bleed the system and go. Does one always need to adjust the release cylinder (clutch action seemed fine before)?
This has got to be a lot simpler than I’m making it. Thanks for any clarification.
