clutch help ! (1 Viewer)
Brooklyn NY
while waiting at a traffic light on the cruisers first run and in gear the clutch engages after afew moments while pedal is still pressed
any ideas
thanx in advance
If you aren't noticing symptoms of air in the line, I'd suspect that your clutch master cylinder or slave are leaking internally. The fluid is leaking past the piston & seal in the cylinder.
Check for leaking master or slave cylinder or hoses. The presure has to be bleeding off, you will soon be out of fluid too!
Nocents
Fluid is getting past a seal somewhere. Look under the rig at the slave cylinder. Is the boot wet/leaking/nasty? If it looks ok, look up under the dash at where the clutch pedal pushrod goes through the firewall. Is it wet there?
Most likely leakdown in the slave cylinder. DO NOT expect it to last long like this. Either replace it or rebuild it asap. If it's post-74(?), you should be able to get a rebuild kit with a new piston at your local auto parts store. Be sure to hone the cylinder as well since the most common cause of failure is a rusty bore that will continue to damage piston seals until it's cleaned up.
Eric
thanx for the info
this place is great
