Good eyeAs bryon said, Do not put washers between the pp and flywheel. This will most likely cause the the clutch to slip. The rounded nut on the adjustment rod needs to be on the other side of the clutch fork. Between the slave and fork. Then adjust.
That's it. Right there. Easy fix.The rounded nut on the adjustment rod needs to be on the other side of the clutch fork. Between the slave and fork. Then adjust.
According to @65swb45 (and subsequent personal experience), the 3 speed pivot ball is long, the 4 speed is short. It appears from the picture that it may be the long one you've installed.Are you using the 4 speed clutch fork pivot?
Refer to post #2That's it. Right there. Easy fix.
