Recently I redlined my engine in a heavy traffic situation (not road rage. Calm down) in 2nd gear, and since then I've been hearing a rattle-like sound when cruising in gear. It's pretty faint, but reminds me of when I had a couple loose torque converter bolts in my '74 Plymouth. I haven't pulled the inspection cover off yet to check the clutch cover bolts, but was curious just how likely this is to even be the case. Is it recommended to have thread locker on these bolts? If yes, would I be correct in expecting just blue thread locker, given the light torque the FSM calls for (only 14 ft-lbs)?
I've seen posts saying the issue could also be the throwout bearing rubbing slightly when the clutch is engaged, so I'll be sure to check that as well while I'm in there.
