cluntch disk
witch cluntch disk has diametre 275mm with 14 spiral for toy diesel?
hdj 80 12V?
thanks for the hepl!
I'm not sure what you mean by "spiral", but this info may help:
B:
Size, Spline OD & No. of Teeth 255 x 28.9 x 21
Flywheel Profile Flat
3B:
Size, Spline OD & No. of Teeth 260 x 28.9 x 21
13BT:
Size, Spline OD & No. of Teeth 275 x 29.7 x 21
Flywheel Profile +0.5mm
H:
Size, Spline OD & No. of Teeth 275 x 27.9 x 10
Flywheel Profile -16.0mm
2H:
12HT:
1HZ:
1HDT:
Size, Spline OD & No. of Teeth 300 x 32.4 x 14
1PZ:
Size, Spline OD & No. of Teeth 260 x 29.8 x 21
1KZ:
Size, Spline OD & No. of Teeth 275 x 29.8 x 21
1VDFTV:
Size, Spline OD & No. of Teeth 300 x 32 x 14
Good info amaurer.
"spiral" i took it as spline .
VT
Friction disc's can be refaced with new clutch material. Torque limiters and springs.
It's more expensive than stock off the shelf.
I have had a few done, for the weird ones. (Lambo's two stage type)
Marco , are you in Fiat-Land ?
Best to fill out your profile , and include your truck type.
VT
Hi VT,
I 've got Land Cruiser HZJ78. 1HZ have turbo CT26 to 60000km broken engine ( 2pistons) . I changed engine form 1Hz at 1HD-T(from hdj80 12V) , and after 100000km broken the trasmission R151F. Broken bearing the output shaft, case (an inner support) and 5th gr.
I've found gerbox H150 part time with 14spline, but my clunth disc have 21spline and 275mm diametre...I found another gearbox H151f full time (from HDJ100) but 14spline..
my LC it trsformed for sahara travel ed expedition . the link is:
http://www.sahara.it/bm/saharaThree/tecnica/il4x4/allestimento-hzj78-for-af.shtml
regards Marko
Nice truck and pictures .
Im sure there will be someone with more information than I know of your truck.
Some pretty smart folks here.
I will give your web page a read and translate. Google Translate
Thanks for sharing .
VT
Marko I don't know enough of your truck to help.
This is the link I tried , but don't have all your trucks numbers .
Use this link :
ToyoDIY.com
And the google Translate ^^^ i posted above for getting the correct numbers..
Best help I can give.
VT
Thanks for the Link of your travels.
Marko io non ne so abbastanza del vostro camion per aiutare.
Questo è il link che ho provato, ma non hanno tutti i numeri di camion.
Usa questo link:
ToyoDIY.com
E Google Translate I ^ ^ ^ postato sopra per ottenere i numeri giusti ..
Miglior aiuto che posso dare.
VT
Grazie per il link dei vostri viaggi.
Marko
I used your posted # of 31250-60260 for searching the clutch disk , 14 Spline 275mm in North America Toy online stores. No luck for that # here.
There are some gents here in South Africa on the forum I believe.
Good Luck.
VT
Marko
Ho usato il vostro inviato # di 31.250-60.260 per cercare il disco frizione, 14 275 millimetri Spline in Nord America negozi di giocattoli online. No per fortuna che # qui.
Ci sono alcuni signori qui in Sud Africa sul forum credo.
Buona fortuna.
VT
Marko
Good Luck.
VT
I think I found whats going on here; European trucks got a smaller clutch!
The information I posted above is from Exedy Australia, so it reflects Gen-market trucks. The EPC has 31250-60230 for the GEN market which this site confirms is 300mm:
http://seekpart24.com/search?c=&q=31250-60230&am=toyota&as=land-cruiser-80-j8-90&at=4-2-td-hdj80-9
Diameter: 300 mm
Hub Profile: 26,8X32,4
Number of Teeth: 14
However the EPC says that Euro-market trucks did indeed have the p/n he posted, 31250-60260. And this site confirms that its 275mm:
Clutch Disc Toyota Land Cruiser 80 (_J8_) 4.2 TD (HDJ80) from LuK - 328 0317 60
Diameter: 275 mm
Hub Profile: 26,6X32,4
Number of Teeth: 14
