I’ve scoured for thunk threads and I’m pretty sure I’ve read them all. I’ve found information spread out among them, and I’ve been working on diagnosing my thunk. Apologies if I’ve missed something, I’ve honestly tried.
I have it from N-D. And I’m not worried about that, hub flanges and OEM CVs will likely fix it, doesn’t seem to have any potential for catastrophic failure.
What concerns me is from a roll, if I let off the throttle all the way, then reapply I get a solid loud thunk. Sometimes when I let off the throttle as well. Nothing at stop and takeoff.
However, I have also started to feel the 100 downshift as I come to a stop. It’s very subtle, but it’s there.
I’ve done differential bushings and greased the crap out of the drive shaft.
I thought about doing rear control arm bushings next, but read about a guy with play in the slip yoke of his drive shaft, so started thinking about that.
I’ve been under it quite a bit. Complete front end rebuild, greasing, wiggling everything. No play in u joints, no play in drive shafts. If I spin wheels with the whole vehicle jacked up there is some play before things start spinning.
BUT.... Today I locked the center diff and tried to recreate the thunk and it was gone. With it going away when I lock the center, it makes me paranoid that there is a potential for it being a much more expensive fix. Frankly, I’m going bleary eyed trying to search this. Jerry has a harness ready to go for me, but I want to budget for a big fix if I need to.
What does this sound like to you guys, catastrophic failure possible?
