Quick details:
-The clunk sound only seems to happen when turning into driveways that have a slight curb. Sort of sounds like a shifting clunking noise.
-This started immediately after getting my gears/lockers installed. Prior to this work, absolutely no sound at all.
-Getting the shop to figure out the issue and fix it is not going to happen (took them a month to do the gears and lockers when they told me it'd be 3-4 days after having an appt scheduled for over a month, took two weeks of calling before they would even take 5 minutes to look at it, etc.).
-I do know that when they removed the front axle that they disconnected the spindles from the UCA and LCA and did not mess with the hubs/bearings.
Things i have checked and all were tight:
Rubber bushings and tightness of the bolts attaching the front axle/diff.
Shock mounts upper and lower.
Sway bar mounts and bushings (bushings on link ends a little worn but 0 play)
UCA and LCA castle nuts
Repacked the front wheel bearings and adjuster nuts and locking nuts are good.
Engine mount bolts and checked rubber bushings
Any thoughts or ideas?
