TPMS light is gonna be soooo annoying.
TPMS!
Pull the bulb, and just keep an eye on things.
Split weights = AMATEUR hour
@Explorer4Hire Let's go simple for a second. Any chance there's a wheel that isn't properly torqued? Has it driven without the shake at all since you did it?
Didn't you just lift it? Maybe something on that end is working loose?
And......looking forward to having a day to myself tomorrow! See y'all there.
PV=nRTIf you're above 32 PSI, you're over inflated. It's the volume of air not the pressure that's holding you up. Bigger tires have more volume so take less pressure. You're on the right track with the chalk test. You can do the math as well but you need to know the corner weights. I think the TPMS pressure threshold can be changed in the computer.
PV=nRT
Yeah. Other Car's Destroyed.Crash has OCD?!?!?!?
What is the place you took it to? Also black electrical tape fixes TPS light warnings.Well, this was the highly touted local place... guess I’ll try another shop maybe?
