Clock Spring on fj80 w/ airbag
Denton, Texas
I have about 135k miles on a 97 cruiser and started hearing the squealing noises when turning left last winter. This winter has produced even more noise. Reading the threads, I understand that I don't have many options with regard to this clock spring.
Please confirm, is my only option to eliminate the noise on 97 cruisers with airbags to go to the dealer for replacement parts? :frown:
Hi.
I am only a 1:banana: wrencher but I am not sure what you mean by Clock spring. When you turn you hear noise from outside the truck? Are you hearing your birfs clicking? I am sure I have been no help but if you search the word Birfs there is alot of info, if that is your problem of course.
As for dealer TOYOTA parts look up C-Dan or American Toyota in the banner adds, He takes really good care of all of us for parts and advice.
good luck.
Steven
Yin,
have you tried to grease the joints on the steering shaft yet?? Iwould not mess with a clock spring, I would not take it to the dealer though, check you phone book and find a body shop, ask who they use for their air bag services, call that guy and get a price from him.
Dave
Loquito, thanks for the welcome...
I am certain that it is not the birfs. The sound comes from the top of the steering column, turning left, when the wheel gets to 30 to 45 degrees from top center. The sound is not dependent on vehicle speed/movement.
Phaedrus - What joints on the column are you referring to? What am I looking for, zerk fittings?
I like the body shop route better than a dealer.
Can the part be re-worked or does it have to be replaced?
I know that going to Cdan is the right thing for this and I am having the same problem. Always use Toyota OEM parts to maintain the reliability. How difficult of a repair is this. I would be interested in the steps as I know the airbag complicates it.
From my understanding of the FSM actually getting to the spring does not look too bad. The airbag issue is the part that I would not want to deal with. The thought of having one deploy when you are working on it scares me off from doing this job even though I get the same squeak in the winter.
I believe Dan has said before that this is not a at home serviceable thing.
I am with mooker - seeing one deployed (laying on the ground and shooting 75 ft up) so it can be shipped was enough for me not to touch mine...on my '96 PU....
Of course I went with the superior air bag less '94 FZJ80! :D
If the clock spring is making noises, I'm under the impression that the only way to make it quiet is a new unit. Now that I think about it since I've seen mine, the clock spring is in a sealed unit. To get rid of the noise it will need to be replaced. If I remember correctly it was cheaper to buy the whole turn signal and wiper + clock spring unit than to buy the clock spring seperate. Something crazy like $40 cheaper for the combined part.
Yin, there are acutal joints (small u jooints) on the engine side of the firewall, what you are talking about is in the spring itself.
FWIW I looked at wrecked cars all day every day and I would not try to work on my air bag system without the proper tools and TRAINING in order to do so. There is the risk of accidental deployment for sure but after that there is the risk that when you need the bags to deploy they will not. I would pay the money to have a pro do it. There are not many rprs that I would say that too.
check with a body shop on who they use for air bag service and give them a call. Let them get the peices for you and then you can rely on their warranty. If you buy parts outside and they jack it up they can blame it on the parts. Not so if they provide them.
as alway this is just my opinion feel free to ignore.
Dave
So, you guys are saying a body shop vs. a Toyota Mechanic?
If the noise is coming from the steering wheel itself it's the clock spring. If the noise is lower and clunky it could be the u joint in the column before the firewall but that is most likely not the cause. I mistakenly replaced mine when I thought it was causing noise. It wasn't.
A scraping noise would indicate the clock spring. A clicking noise could also be the plastic bushing in at the bottom of the steering column. I know mine isn't great but when I went to go replace it I soon realized I needed to take the column apart and didn't have the special tools to do it. So I just greased the old bushing instead. It's quiet for now.
To replace the clock spring you will need to remove the air bag from the wheel and disconnect it's connection. To do this the battery must be disconnected for at least 90 seconds. At least this is what the FSM states. Also any sort of charge against the terminals could set the air bag off so being grounded might be a good idea. The air bag itself is held on by 2 torq screws accessed through the side covers in the wheel. Once those are backed out (they stay in the wheel when they are screwed out) the air bag is just pulled off of the wheel. From here you unclip the bag as stated before and remove the steering wheel as stated in another thread. Then you should be staring at the clock spring unit. I haven't taken this off yet, but it should just screw off. Everything goes back together as before. Also make sure to mark the position of the steering wheel on the splines before you take it off. It's not keyed so the previous position is important if you want it straight like it was before.
Dave's thought on the warranty is a good as well, but I'm too cheap for that.
Also if anyone kills themselves doing this, it's not my fault. :D
Note that I have taken my airbag out multiple times following this procedure.
We just talked about this a couple weeks ago, search must be broken.
It's the clock spring, also known as the spiral cable. Guy in my club just had it done last spring and is was $300 (like $200 for the part and an hour of labor). There is nothing you can get in to grease to stop it. Mine does it too. Unless you're real comfortable dismantling the airbag, I'd have a shop do it.
Thanks for the information. What can a person do to protect themselves. In addition to grounding yourself, can you wear insulating gloves or wrap the connection?
What type of connection? Is it a typical two prong plastic connector?
Sounds like the majority of the fix is still $200 for a part. For another $100 you can save some on health insurance...
I recently pulled both bags on a 97
The connectors are similar to the rest of the connectors in the 80 but they are self shorting, as soon as they are disconnected the squibs pins are shorted together by a bar that drops down, Also these plugs have multiple locking setups instead of the single lock like the rest of the vehicle, they are also bright yellow.
Although it is not to be taken lightly handling the airbags is not dangerous if you do what you are suppose to do. No abnormal precautions beyond what is in the FSM need to be observed,
I would not wear insulating gloves as insulators carry static, nor would I wrap the connector with sticky tape, just take the air bag off and set it to the side wile you do your work.
Clocksprings cannot be taken apart and lubricated. I replace alot of these at work, and there's no repairing them. I've not seen what the LC one looks like, but on the Mercedes there is two squib connectors, and a connector for the cruise, radio controls, etc.
I would not advise one to change their own, but if replacement is attempted, disconnect the neg. battery cable first! Funny I say that, but no one I know at work does!! I have replaced clocksprings under warranty for making noises instead of just open circuits.
sounds similar I just happen to have a pic.
Hmm, I think I have this noise and have often wondered about it. No air bags for me though, so I'll need to do some searching...
