Hi,
I have a question about clearance between clutch cover and T/O bearing when pedal isn't pressed.
My FJ62 has manual transmission and used same parts & mechanism about clutch with later US FJ60.
Until a few days ago, I thought that there's a little clearance exists between clutch cover spring and t/o bearing but after did comprehensive checking about my FJ62's clutch system, I found that there are no clearance always.
So it means that T/O bearing is always rounding and rounding.
When I press the slave cylinder rod and give clearance, it return to contact bearing and clutch cover.
Is it OK ? or if it's not correct situation, is there any way I can correct this ?
Attached photo was taken when clutch pedal wasn't pressed.
I saw that pre 84 clutch system had fork return spring but mine don't have.
If anyone knows about this, please inform me.
Thank you,
Oh, Min Seok
Thank you,
Oh, Min Seok
