Cleaning injector pipes.
Johannesburg
This bunch of snakes from a 12HT has sat like this for a long time and while I can blow through them, who know what lurgies have found there way into the pipes.
I can't afford new ones, and who knows if they are even available.
What would be the best method to get em nice and clean inside, and less importantly, outside.
G
Huntsville AL or Yuma AZ
Blow them out with brake clean and compressed air. Then install and leave injector side loose while turning engine over for a while. Put some cloth at other end covering injector inlet. That'll be about 2800psi of diesel blowing them out. I do this after having the injector lines replated.
Perth Western Australia
I would soak them,maybe in Coca Cola. It makes coins shiny. Some builders lime in water destroys corrosion.
Diesel fuel injection shops can make and repair injector lines.
