clanking sound
Discussion in '60-Series Wagons' started by LoneRanger, Mar 2, 2007.
  1. LoneRanger
    LoneRanger
    3,061
    Media:
    1
    Albums:
    1
    150
    Mar 15, 2005
    on stage
    Ever since I've owned my 60 (ca 2yrs) I've noticed a clanking sound that seem to emit from the region of the drive shafts. I hear it occaisionally when I take off from a stand still or brake. Any ideas on what it might be?
  2. chitown40
    chitown40
    2,109
    22
    Feb 9, 2004
    Buffalo Grove, IL
    Sounds like the slip yoke on the rear drive shaft. Best way to fix is to disconnect the rear shaft, split the yoke. clean and re-grease. If you just fill it from the grease fitting you could lock the shaft.
  3. LoneRanger
    LoneRanger
    3,061
    Media:
    1
    Albums:
    1
    150
    Mar 15, 2005
    on stage
    thanks. I'll check that.
  4. LoneRanger
    LoneRanger
    3,061
    Media:
    1
    Albums:
    1
    150
    Mar 15, 2005
    on stage
    Pulled the driveshaft today and I expected it would make the clanking sound if I shook it around. No deal. I took the slip yoke off and it is in good shape. I regreased and will reinstall.
    Still trying to figure this sound out. It's getting worse--ranges from a squeeking to what sounds like something dragging or banging around. It seems to increase and decrease with rpms. Definately coming from below, not the engine.
    any ideas? I thought of putting the truck on stands and running it while someone shifts so I can pinpoint the location of the sound. Bad idea?
  5. PAFJ
    PAFJ
    1,626
    Media:
    17
    Albums:
    1
    Jul 27, 2005
    Roseville, CA
    Just a thought... is your driveshaft in phase?
    Actually... I doubt if your driveline was out of phase it would make the noise described. Possibly a worn pinion gear or bearing? Is there an abnormal amount of play in your driveline?
  6. wardfoto
    wardfoto
    1,341
    Albums:
    1
    Jan 4, 2005
    2nd star to the right
    while you've got the driveshaft off, check the pinion nut. mine did something similar to this, and that's what it was. bad if you don't catch it on time.
    i did, but somebody else fixed while i was out of town, and the second time it did it, it dropped the pinion. bad, bad, bad.
  7. John McVicker
    John McVicker SILVER Star
    2,170
    414
    Jul 11, 2005
    Big Pine, CA
    U joints. If required buy OEM only.
    HTH John
  8. TheJackRabbit
    TheJackRabbit
    661
    16
    Sep 21, 2006
    Sangre de Christo Mtns of North Central NM.
    You could be missing a few bolts from a track shoe...
    Oh, sorry. I get the Land Cruiser forum confused with the Cat forum.
    Both are good off road.:grinpimp:
