clamps for brake tubes on the front axle housing
Discussion in '40- & 55-Series Tech' started by vikor, Nov 10, 2018.
  1. vikor
    vikor SILVER Star
    24
    39
    Nov 8, 2018
    France
    hi every body
    i looking for clamps for my brake tubes on the front axle housing
    this parts are unavailable with dealers toyota
    how have you solve this problem of clamps?
    following one picture the coating rubber arrond the part is gone ..
    thank you for your help or solutions
  2. spotcruiser
    spotcruiser Geezer SILVER Star
    3,605
    772
    Jan 30, 2003
    Western WA
    Make your own.
    4x4veteran likes this.
  3. vikor
    vikor SILVER Star
    24
    39
    Nov 8, 2018
    France
    hi,
    yes it's possible (diy)
    but the probleme is the coating ( plastic ? rubber?) who exist on this parts (to protect the tube)
  4. 4x4veteran
    4x4veteran
    417
    1,932
    Nov 6, 2013
    There is a rubber dip for tools that might work and you can get it in colors for that designer look.
  5. jgeoffr
    jgeoffr SILVER Star
    526
    Media:
    9
    Albums:
    1
    485
    Apr 1, 2013
    Dhahran, K.S.A.
    Bead blast, replate and dip several times in plasti-dip.
    Not the best pic but the best I've got.
    -Geoff
    mrboatman, numby, vikor and 2 others like this.
  6. vikor
    vikor SILVER Star
    24
    39
    Nov 8, 2018
    France
    hi,
    i looking for this clamp for my two BJ40 ( all my clamps are out of order)
    do you know a dealer ( who can ship in France)? or a supplier for this clamp ?
    i am ready to buy 20 of them
  7. jgeoffr
    jgeoffr SILVER Star
    526
    Media:
    9
    Albums:
    1
    485
    Apr 1, 2013
    Dhahran, K.S.A.
    vikor likes this.
  8. vikor
    vikor SILVER Star
    24
    39
    Nov 8, 2018
    France
    thank you for your useful advice and the link amazon
  9. numby
    numby
    831
    29
    May 3, 2009
    I use Plasti-Dip in the can - not the aerosol. Prepare the item for paint, etc. Apply your finish (zinc, paint, powder coat, etc) then, after appropriate drying time, dip the clamp in the Plasti Dip can up to the desired depth. After you pull it out then quickly smooth out any tail or curly Q before it skins over. You only have a few seconds in my experience. Sometimes you can lightly shake or vibrate the item to get the Plasti Dip to smooth out. Then let it dry overnight. It will shrink up and look almost exactly like the OEM rubber coating. You can recoat/re-dip after it has cured but you will want to overlap the second coat beyond the edge of the first coat so plan a head if you have a very specific point where you want the coating to end. I did some frame mounted wiring harness clips and my brake booster hose clamp 20 years ago and the rubber still looks good on all of them.
    vikor likes this.
  10. Pete
    Pete
    398
    83
    May 19, 2004
    Midwestern Flatlands
    I've used heat shrink tubing. Harbor Freight has a kit with sizes ranging from about a 1/4" up to 1" for only a few bucks. You can put 2 or 3 layers on to get a thickness you like.
    Pete
  11. Splangy
    Splangy SILVER Star
    6,810
    1,214
    Aug 4, 2009
    New Hampshire
    This style is still available from Toyota.
  12. vikor
    vikor SILVER Star
    24
    39
    Nov 8, 2018
    France
    hi,
    last week
    i was gone to me dealer Toyota , he had checked with his EPC , impossible to have this parts
    if you can give me some Toyota reference (same style and available)
    thank you
  13. sved
    sved
    593
    85
    Feb 24, 2012
    Sweden
    made my own in stainless steel.cut a rubber hose in pieces which will fit over the brakelines and inside the clamps.No dip or paint,no rust.
    and also on the fuel lines.
    vikor likes this.
  14. vikor
    vikor SILVER Star
    24
    39
    Nov 8, 2018
    France
    it's lifetime warranty!
    Congratulations for your stainless steel parts, but what is the secret to form correctly the round?
  15. sved
    sved
    593
    85
    Feb 24, 2012
    Sweden
    1mm stainless Steel wrapped around a 10 mm round pin.Other shapes formed with flat bars and hammer and benchvise .
    Works on a 60 frame so should be no problem on a 40/55 frame.
  16. AlaskanWheeler
    AlaskanWheeler SILVER Star
    1,191
    401
    Jul 8, 2004
  17. shelfboy1
    shelfboy1 SILVER Star
    4,799
    479
    May 7, 2006
    erie pa
    i found some insulated ones at the local h ware in the electrical dept
