1987 FJ60. Currently swapping my broken Weber for a new City Racer carb and will be using the original air cleaner assembly. The PO did a Desmog and some of the work needs to be fixed. The following parts are missing/removed: the original carb insulator plate is missing, HAC, EGR, Cat, charcoal canister, all VCVs and emission parts/components. I do not require a smog inspection in my county/state. I have a spare OEM carb that I will eventually send off for a rebuild that has a working A/C Idle up which I’ll transfer to the new carb. I have removed the Man-a-Fre carb block.
Questions:
1. Do I need to purchase an OEM carb insulator?
2. I have two new unused VCVs from City Racer. Will I need to use both for the swap? The vacuum hoses on the oil filter side were routed from:
1. Distributor advance to carb
2. Distributor cap vent #1 to fire wall cabin filter
3. Distributor cap vent #2 to bottom of stock air cleaner
(All of the above were run independently without using a VCV)
3. Should I remove and cap both BVSVs? Nothing has every been connected to them since I’ve owned the truck.
4. Plan to use City Racer carb solenoid instead of OEM stock from spare carb.?
5. New PCV valve, grommet and hose to existing EGR plate or other options?
6. The original choke cable was never used with the Weber. Is it recommended to connect it with the new City Racer carb.?
7. There is a yellow blade connector wire next to the the large green ICS connector previously connected to the Weber choke What do I do with this wire???
8. Would re-installing a charcoal canister help with drivability.....gas fumes?
Any help would be greatly appreciated
