Cigarette lighter blown but fuse OK (2 Viewers)
The Saratoga slums, CA
This past weekend I tried to use a small DC/AC converter to run an air mattress pump and I blew the cigarette lighter. I have yet to take my multimeter to the wiring but I have checked the fuses along that circuit according to the factory electrical manual. The dash fuse as well as the fusible link under the hood are still OK. I pulled the lighter and there are no melted wires or connectors visible.
Before I start pulling things apart to search for fried wires I thought I'd check here to see if anyone has had a similar experience and where they located the problem. Anyone?
Search and ye shall find :D
Look here
There were some other threads that turned up on the search as well -- they might be of more help.
Just worked out that way this time...
I tend to start the search w/o specifying a forum, if I get too much garbage, then I fine tune. Sometimes it works. :)
I recall another thread on this topic in the 80s tech forum -- I didn't spend much time looking for it though.
I just ran out to the truck in the parking lot at work. Sure enough, even though the link looked intact, I dug through the insulation and it was burnt through underneath. It looks like it'll be a PITA to replace that little link.
I knew there was another thread...
Take a look at this one
E9999 had the same problem as you did -- this was the thread I was looking for originally.
Hopefully this helps.
