OP, good luck with the flush. Now's a good time to refresh hoses too. Zack, am I the only one that has a hell of a time reaching my petcock valve? Is there some kind of trick to it? Mine is located on the driver's side and there are smaller lines, I think ps lines, that are in the way. Sorry for hijack.Once all of the big chunks are out you can use the radiator drain petcock instead of disconnecting the lower hose.
1FZ-FE engine block drain plug location
@Jgunner and I are local to each other and we were talking about this earlier. What does everyone think of using the vinegar approach to cleaning things up in the radiator too?
I haven't done the vinegar method myself but have read helps cleaning the radiator out. Has anyone else heard the same or anything differently?
I am not sure I would use vinegar but I would use something like the Peak brand flush, but depending on condition you might need to wait for summer since you leave that in with water and run if for sometime and I don't think it has any freeze protection.
