I have a 1972 (June 1972) J40 Toyota Land Cruiser.
350 chevy conversion.
This vehicle originally used external regulated alternator system. At the time eight years ago I wasn't very electrically inclined mostly just lazy really...and I ended up buying a hitachi one wire hundred amp alternator.
Fast-forward about six years later I have decided to get the vehicle back on the road however I am running multiple accessories now I did not have six years ago. I was thinking of a dual battery set up ..both batteries are isolated from each other and do not attach, they are independent and unfortunately I have purchased 150 amp powermaster one-wire that I have not used. I've read articles from MAD ELECTRONICS I am looking to exchange for a power master 150 amp 3-wire since most of my amp draw if everything on at once doesn't really exceed 137 amps. Maybe. The following is where I need guidance.
As mentioned earlier this is a Toyota Land Cruiser with a 350 Chevy conversion this Chevy conversion is a 1977 L82 C-5 Corvette motor it runs it works everything is fine. I've driven the car plenty of times with the hundred amp alternator but all I did was disconnect the external regulator. Being that this is a conversion and not a typical exchange of an alternator, where would you start to find out how to wire this into the original Toyota harness? where would I begin to look on how to wire this chevy 3-wire internal regulated alternator up into an original Toyota harness?
I will be reading the schematic for the 72 voltage regulator and maybe I'll see if I can splice in the three wire into the original external regulators wiring I think it still hanging somewhere I appreciate the help and direction. The following is what I'm concerned about whether to use a junction block for auxiliaries and run that from aN AMP voltage sensing unit juncture or just run it straight off an auxiliary battery that's being charged by the alternator. Now according to MAD electronics that's not a great thing to do
The original units that are powered by the vehicle I suppose would be headlights for one tail lights brake lights blinkers windshield wipers ignition switch at least I'm not really sure what else I would need that's electrically connected to my starter battery for the harness. My accessories aren't really mostly accessories but probably not needed... if I went back to stock application
What's on the vehicle:
Flex-a-lite Black magic extreme 180 "3300" cfm 15" fan -18amp draw
Holly electric blue pump -3amp draw
Derale Electra-cool two core oil cooler with 650 cfm tornado 10" fan- 5 amp draw
Viair 400c air pump -28 amp
Viair 300 air pump -15 amp draw
Arb air locker pump -9 amp draw
Forward Lights spots 130w -11amp draw
Forward Lights flood -8 amp draw
Side lights corner spots
Rear light flood
Rear light 30w backups -4 amp draw
Surge pump for fuel can siphon or bilge pump work lol
Msd 6al - 1amp /1000rpm- 2-3 amp draw
Cb uniden 78 elite tuned
Gps garmin Oregon 550t
Inverter one plug outlet
Winch Bellevue/warm type 8274 -50-500 amp draw
Headlights -4 amp draw
Brake lights
Horn
Blinkers
Wipers
Ignition
I know I have more s*** running but I'm just concerned if I need to run a larger alternator with a dual battery set up which is just making the stuff more complex.
My concern is running my auxiliaries directly off of a bus bar I guess you would call it from the battery instead of trying to take power from the alternator and let the voltage sensing device tell the alternator how much to give and how much to let go and how much to keep in rather than just charging my battery hot all the time. Voltage sensing item is a MAD Ign. sellable item from their site
What to run off primary and what to run off secondary
What type of ISO?
Use cut off switch
I guess I'm also concerned about a remote starter solenoid and the reason I ask is because I live where it's an average I don't know 120 just kidding it's very very hot in Phoenix and I know that if I run a remote starter solenoid to my Chevy high torque starter I will get more power amperage through a cable with little resistance that if I try to run it to the starter itself like I've been doing....just gets too hot and I can't start the vehicle. My Starter hi-torque mini...it's a permanent magnetite starter I hook it up the normal way with a "ford style solenoid" that it's gonna have run- on because it's going to create its own power when it starts by spinning by the magnets or whatever they do inside those things. So the diagram that I saw is basically power goes in the one side of the remote starter solenoid turn the key the power connects and it goes through the other post to the starter ( jumper cable goes from s post to bat post on original solenoid)
however Power when key is on should come out of the other side to the remote starter solenoid not in this diagram....to route line to a high torque...this diagram shows power going into right post of remote starter solenoid from the battery but instead of it coming out the left post to the part of the starter solenoid on the starter it has has a secondary cable coming off the same right post to the starter. Instead on the jumper of a small wire which is used from the bat+ post on starter solenoid to the little S post on the starter solenoid which is on the starter. I am confused. I am using 1/0 gauge
From the battery to the remote solenoid I want to use the same gauge to the starter post however according to the picture I would be using the same gauge from the same side that the battery cable is going to on the remote starter solenoid, I am trying to get away from having a hot start at all times. My concern is if I have the battery cable going to the right post of the remote starter solenoid and on the same post coming off to the starter solenoid on the starter won't that still always be hot? I'm not sure if this really matters I may never use it if the starter works and functions like itshould but I'm just concerned why I've got a battery going in to the remote starter solenoid and a cable coming off of the same"in" post to the starter solenoid on the starter? Never had a perm magnet starter... does this schematic look valid?
Rear light flood
Brake lights
Horn
Blinkers
Wipers
Ignition
What type of ISO?
Use cut off switch
