I searched...
I did the canister test per the FSM- 123k on our '97. I have no issues, just doing routine maint. The FSM says something like .23 (point 23) psi to blow into it to see if air comes out the other holes. The other test is 1 psi. Is this right? Nothing comes out at those WAY low pressures. I used about 20 psi and heard the valve clicking and got air out per the test, but only at the higher pressure. Couldn't get anything to blow out by using my own breath.
What have others done, seen for test, pls? The 'cleaning' at 40 psi produced no debris out of the canister.
Thanks.
Thanks.
