Checked your door latch screws lately?
Holland, Michigan
My wife noticed a loose screw (love that woman!) on the cruiser. Several others were barely finger tight. I haven't picked up an FSM yet, but whatever the torque was it didn't hold them in place. These have plastic cone washers under the flat-heads, and they're flat-heads in sheet metal, so it'd be difficult to torque them enough to hold. Especially in this application of slamming repeatedly. The screws looked perfect, no corrosion or even discoloring of the galvanizing. No evidence of thread locking compound either. I put medium strength locktite on all twelve, that should fix them.
good to know, thanks for the heads up...
(I'd use low strength on those myself, hate to struggle with bolts and screws...)
ooooh, Torx...? love those...
I'm out of low strength, use it everywhere I used to use anti-seize. I keep waiting for it to come out in a stick, love the stick, but it's only medium and high-strength.
Note the ball end torx, sort of bought these by accident, hasn't been handy yet.
One of mine actually fell out the other day, pass side rear door. The other 2 were very loose too. I checked the other doors, a couple were slightly loose. I'll keep an eye on them in the future.
I didn't think to report it, but same things happen
The front passenger door needed to be closed more heavily (and loudly) ...
All fine now
well, sure enough, 3 or 4 of mine were a tad on the loose side (1/2 turn more possible or so)
thanks for the headsup
This seems like a design oversight. The nylon cone washers would soften the door slam nicely, suspending the latch on nylon. I don't see how they expected these to stay tight without thread locking compound or a jamb nut. Maybe they made this change late in the design, and didn't think it through as well as they should. I think medium-strength thread locker is a good idea, they'll need to take a lot of slamming and vibration. The heads are easy to access, and the big torx is unlikely to strip, they should come out easily enough. I use a lot of medium-strength threadlocker, fasteners usually come out harder but not stuck. I did have trouble with some #4-40 screws someone put in with high-strength, but only a couple hundred of them.
I don't know how easy it'd be to find new screws, these are odd. They might only come with a new latch or door or something. And I'm not sure what would happen if one got really loose, would it hit the sheet metal of the body and make a nasty gouge? And bend the screw? Maybe bend the latch?
44 in.lbs. and they are listed as a "precoated part" which indicates they had loctite (ThreeBond actually) on them. They also specifically state that when reassembling, apply ThreeBond 1324. ThreeBond 1324 is mid-strength.
Hmm...that's interesting. I looked carefully at each screw, some had a small dot of amber grease on the tip. Fasteners are usually precoated by the vendor with thread-locker, must've missed mine.
Not trying to hijack the thread, but this seems pertinent. My driver's side exterior handle is loose. The front end of the pull handle pulls a few millimeters away from the door when I open it. Anyone know how to tighten the bolts? Do I have to take the interior panel off the door? I'd hate to have to pay Toyota to fix something so minimal.
Unfortunately you do have to remove the door panel. The whole door handle unit including lock cylinder is held on by three bolts if I remember correctly. There is an access hole where you will get access to these.
"My wife noticed a loose screw (love that woman!) on the cruiser".quote]
Thanks for the tip. I wont say anything about your wife (The wonderful woman who married you) and her uncanny ability.
