Is this check valve still available? I can't find a part number on a parts diagram. Mine is bad.
90917-10038. Discontinued.
Different flow rate. I no longer have access to an old chart. It may not matter much however.
That’s a one way valve for the HAC system. It keeps vacuum on the secondary advance diaphragm after the motor is shut off at altitude so when you start back up you will be advanced. HAC will still work if it is removed or not holding vacuum one way, timing just won’t be advanced on startup at altitude.
Since it’s a check valve it’s one way only
Precisely, since it’s a check valve, flow rate isn’t applicable. Part no. I added is also only a check valve.
The FZJ80 (1FZ-FE) uses a check valve that looks very similar (it's also used on just about every Toyota made). It's orange & black. Still available. I bet it works. Only $6. Would be worthwhile to check (ha!) it out.
