So this weekend I drained and refilled both diffs and the transfer case with Amsoil 75W90 "liquid gold" as I read another poster say once.
I also did the "shadetree" drain of the automatic transmission fluid - removed the drain bolt and jacked the front end up, this got me about 3qts out. I then replaced the bolt and added 3 new qts of Amsoil ATF. Removed the return hose (from the cooler into the transmission from another write-up) until about 2 qts came out, refilled another 2 qts. Did this hose drain three cycles.
When I first checked the level it seemed a bit low on the stick, took it for a drive around the blocked and noticed 2-3 second hesitation in the shifting. Added another qt, got better still some hesitation. Added another .5 to .75 qts. Shifting fine now, driven for about 10-12 miles on it and it seems fine.
QUESTION: should I be checking the fluid level when idling or not?
For some reason I'm having the hardest time getting a comfortable reading. When not idling but cold, the fluid is at about 1" up from the bottom of the stick, below the Cold mark. When idling cold/cool, the stick seems to have some fluid residue up past the hot marks
Seems like such a simple task - any observations or helpful hints would be appreciated. Thanks!
