My check engine light came on yesterday. I was expecting a code 21 for the O2 sensor since I was tightening a bolt on my sliders and bumped it a bit.
It won’t clear or it comes back on immediately upon starting the truck. I’ve had the battery disconnected and the EFI fuse pulled.
However, when I go to read it the CEL just blinks consistently which indicates the system is working and there are no codes. What gives?
The truck runs the same— maybe a bit rougher at idle but I might be imagining that. There is some white goo on the diagnostic ports. I’m hoping it’s just dielectric grease. This is the first time I’ve had to read a code since buying the truck in July 2017.
Reading 3FE engine codes at home
I couldn't find this on Mud. Thanks to Aaron (Mr 2FE), he put this together some time back. I have had several questions about reading the check engine light on a 3FE lately, so here it is. I'll be adding it to the FAQ. Get a Haynes, Chilton’s, or a Factory Service Manual (FSM) For the FSM...
forum.ih8mud.com
