I just got an email from RockAuto on these closeout parts specials. Seems like some awesome deals if anyone needs any of this.
Part Type: Belt
Part Type: Brake Pad
Part Type: Brake Pad Shim Kit
Part Type: Caliper
Part Type: Disc Brake Hardware Kit
Part Type: Hydraulic Hose
Part Type: Master Cylinder
Part Type: Rotor
Part Type: Wheel Seal
Part Type: By-Pass Hose
Part Type: Water Pump Gasket
Part Type: Battery Cable
Part Type: Voltage Regulator
Part Type: Air Control Valve Relay
Part Type: Blower Motor Relay
Part Type: Fuel Injection Relay
Part Type: Headlight Relay
Part Type: Horn Relay
Part Type: Radiator Fan Switch
Part Type: Rear Window Defroster Relay
Part Type: PCV Valve
Part Type: Exhaust Valve
Part Type: Intake Valve
Part Type: Oil Filler Cap
Part Type: Oil Filter
Part Type: Piston Ring
Part Type: Semi-Circular Plug
Part Type: Thrust Washer
Part Type: Timing Cam Gear
Part Type: Air Filter
Part Type: Fuel Filter
Part Type: Fuel Injection Pressure Regulator
Part Type: Fuel Injector
Part Type: Fuel Injector O-Ring
Part Type: Fuel Pump
Part Type: A/C Evaporator Core
Part Type: Heater Hose
Part Type: Distributor Cap
Part Type: Distributor Rotor
Part Type: Ignition Control Module (ICM)
Part Type: Spark Plug
Part Type: Spark Plug Tube Seal
Part Type: Spark Plug Wire
Part Type: Spark Plug Wire Set
Part Type: Control Arm Bushing
Part Type: Shock Absorber
Part Type: Filter
Part Type: Oil Temperature Sensor
Part Type: Lug Stud
Part Type: Belt
- Manufacturer: DURALAST
- Part No: 17365
- Notes: A/C Cmpr Belt 24 VALVES
Closeout Price: $8.98Only 8 Remaining!
- Manufacturer: WAGNER
- Part No: ZX606
- Notes: Rear; OE Semi-Metallic
Regular Price: $18.63Closeout Price: $9.85SAVE 47%Only 13 Remaining!
- Manufacturer: FRICTION MASTER
- Part No: CMX502
- Notes: Front Ceramic Pads PROFESSIONAL GRADE
Closeout Price: $14.80Only 7 Remaining!
- Manufacturer: AUTOSPECIALTY / KELSEY-HAYES
- Part No: 2250201
- Notes: Front Organic; Axxis Deluxe Plus
Closeout Price: $18.06Only 2 Remaining!
- Manufacturer: AUTOPART INTERNATIONAL
- Part No: 93057
- Notes: F Semi Met Pad Kit PREMIUM
Closeout Price: $19.21Only 1 Remaining!
- Manufacturer: CENTRIC
- Part No: 10705020
- Notes: Front
Closeout Price: $19.30Only 1 Remaining!
- Part No: 1650212
- Notes: Front Original Equipment; PRO SERIES CERAMIC
Closeout Price: $20.89Only 12 Remaining!
- Manufacturer: BECK/ARNLEY
- Part No: 0881430C
- Notes: Front
Closeout Price: $21.79
- Part No: 0842027
- Notes: Rear
Regular Price: $4.15Closeout Price: $2.18SAVE 47%
Part Type: Caliper
- Part No: 4156558
- Notes: Rear Left; Un-Loaded
Closeout Price: $31.79Only 6 Remaining!
- Part No: HK1033
- Notes: Front; w/4 Wheel Disc Brakes
Closeout Price: $9.11Only 14 Remaining!
- Part No: 0841447
- Notes: Rear
Regular Price: $19.88Closeout Price: $10.46SAVE 47%Only 7 Remaining!
- Part No: BH124730
- Notes: Front; R.H.; Inner
Regular Price: $16.47Closeout Price: $8.65SAVE 47%Only 1 Remaining!
- Part No: 0731654
- Notes: 4-Wheel ABS; Rear Disc brakes; Rear Right
Regular Price: $19.37Closeout Price: $10.17SAVE 47%Only 1 Remaining!
- Part No: 0729162
Regular Price: $132.79Closeout Price: $72.79SAVE 45%Only 5 Remaining!
Part Type: Rotor
- Part No: 140778450
- Notes: Rear Disc Brake Rotor w/4 WHEEL DISC,ULTRA
Closeout Price: $17.14
- Manufacturer: GUARDIAN / ONE SOURCE
- Part No: 52125354
- Notes: Front
Front Disc Brake Rotor
Closeout Price: $39.79Only 1 Remaining!
- Manufacturer: SKF
- Part No: 24635
- Notes: 4WD; Front
Closeout Price: $3.40Only 9 Remaining!
- Manufacturer: GOODYEAR
- Part No: 63912
- Notes: Molded; Pipe 5 to Valve; Cut to Fit
Regular Price: $6.90Closeout Price: $3.62SAVE 48%Only 10 Remaining!
- Part No: 0394105
- Notes: PUMP TO HOUSING
Regular Price: $3.84Closeout Price: $2.00SAVE 48%Only 1 Remaining!
- Manufacturer: STANDARD MOTOR PRODUCTS
- Part No: A434L
- Notes: Cold Weather Equipped; Battery To Switch
Regular Price: $10.76Closeout Price: $5.59SAVE 48%Only 4 Remaining!
- Part No: A366UT
- Notes: Exc. Cold Weather Equipped; Battery To Ground
Regular Price: $16.59Closeout Price: $8.63SAVE 48%Only 1 Remaining!
- Part No: VR510
Closeout Price: $67.79Only 1 Remaining!
- Manufacturer: GUARANTEED PARTS
- Part No: 415040
- Notes: Air Ctrl Valve Relay
Closeout Price: $7.76Only 1 Remaining!
- Part No: 415143
- Notes: Blower Relay
Closeout Price: $5.55Only 12 Remaining!
- Manufacturer: KEMPARTS
- Part No: W810
- Notes: Main Relay
Closeout Price: $7.97Only 12 Remaining!
- Part No: 415627
- Notes: Headlamp Relay
Closeout Price: $20.79Only 14 Remaining!
- Part No: AR406
- Notes: Horn Relay
Closeout Price: $5.23Only 3 Remaining!
- Part No: RY123
Regular Price: $25.79Closeout Price: $13.68SAVE 47%Only 3 Remaining!
- Part No: 2011678
- Notes: w/Gauge
Regular Price: $7.58Closeout Price: $3.99SAVE 47%Only 2 Remaining!
- Part No: W810
- Notes: Defogger/Froster Relay
- Part No: PCV224
- Notes: PCV Valve
Closeout Price: $0.75Only 11 Remaining!
- Part No: PCV181
- Notes: PCV Valve
Closeout Price: $2.77Only 1 Remaining!
- Manufacturer: ACDELCO
- Part No: CV776C
- Notes: VALVE,PCV
Closeout Price: $2.83Only 4 Remaining!
- Part No: 0213553
Regular Price: $9.63Closeout Price: $5.17SAVE 46%Only 1 Remaining!
- Part No: 0213554
Regular Price: $7.10Closeout Price: $3.86SAVE 46%Only 2 Remaining!
- Manufacturer: STANT
- Part No: 10080
Regular Price: $3.31Closeout Price: $1.73SAVE 48%Only 12 Remaining!
- Part No: 0418077
- Notes: [Oil Filter]; From 5/96;
Closeout Price: $2.64Only 1 Remaining!
- Part No: 0138289
- Notes: DOHC; STD
.50MM/.020"
Closeout Price: $54.79Only 4 Remaining!
- Part No: 0396214
- Notes: Valve Cover
Regular Price: $1.91Closeout Price: $1.02SAVE 47%Only 12 Remaining!
- Part No: 0150771
Closeout Price: $14.07Only 1 Remaining!
- Part No: 0250438
- Notes: Intake
Closeout Price: $7.58Only 2 Remaining!
- Manufacturer: FRAM
- Part No: CA376
Regular Price: $10.41Closeout Price: $5.40SAVE 48%Only 1 Remaining!
- Part No: G7731
Regular Price: $20.79Closeout Price: $10.82SAVE 48%Only 1 Remaining!
- Part No: PR115
Closeout Price: $44.79Only 1 Remaining!
- Part No: 1550262
Regular Price: $54.79Closeout Price: $30.79SAVE 44%Only 1 Remaining!
- Part No: 1580090
Regular Price: $3.73Closeout Price: $1.96SAVE 47%Only 7 Remaining!
- Manufacturer: BOSCH
- Part No: 69602
Regular Price: $199.79Closeout Price: $109.79SAVE 45%Only 7 Remaining!
- Part No: 1562156
- Notes: EVAPORATOR,A/C
Regular Price: $198.79Closeout Price: $110.79SAVE 44%Only 1 Remaining!
- Part No: 1382111
- Notes: Blower Motor AIR CONDITIONED
Closeout Price: $30.79Only 2 Remaining!
- Part No: 1380061
- Notes: New Blower Motor AIR CONDITIONED
Closeout Price: $42.79Only 7 Remaining!
- Part No: 4202
- Notes: Heater Hose PIPE 5 TO VALVE - CUT TO FIT
Closeout Price: $4.76Only 5 Remaining!
- Part No: JH217
Regular Price: $10.10Closeout Price: $5.28SAVE 48%Only 2 Remaining!
- Part No: E312C
- Notes: CAP,DISTR
Closeout Price: $8.56Only 1 Remaining!
- Part No: JR124T
Regular Price: $2.14Closeout Price: $1.12SAVE 48%Only 3 Remaining!
- Part No: W2041
- Notes: Rotor
Closeout Price: $1.67Only 18 Remaining!
- Part No: E400A
- Notes: ROTOR,DISTR
Closeout Price: $3.99Only 4 Remaining!
- Part No: LX721
Closeout Price: $157.79Only 6 Remaining!
- Manufacturer: SPLITFIRE
- Part No: CC392D
- Notes: Spark Plug SPLIT V ELECTRODE
Spark Plug COPPER CLASSIC - OE STYLE
Closeout Price: $2.17
- Part No: PP392D
- Notes: Platinum Plug TRIPLE PLATINUM SPLIT V ELECTRODE
Platinum Plug PLATINUM CLASSIC - OE STYLE
- Part No: 0396360
Regular Price: $3.88Closeout Price: $2.05SAVE 47%Only 2 Remaining!
- Manufacturer: BWD/NIEHOFF
- Part No: CH5601
- Notes: Premium Wire PREMIUM
Closeout Price: $36.79Only 1 Remaining!
- Part No: 1756046
- Notes: PREMIUM; Diameter: 5mm; Black Wire; Mag Core 500 ohm/ft; Jacket Material: Blended EPS
Regular Price: $57.79Closeout Price: $30.79SAVE 47%Only 1 Remaining!
- Manufacturer: TRW
- Part No: 12739
- Notes: Lower Control Arm Bushing/Kit FRONT SUSP
Lower Control Arm Bushing/Kit FRONT SUSPENSION,FRONT
Closeout Price: $9.27
- Manufacturer: TRW
- Part No: 12740
- Notes: Lower Control Arm Bushing/Kit FRONT SUSPENSION,REAR
Lower Control Arm Bushing/Kit FRONT SUSP REAR
- Part No: 0457000
- Notes: Lower; FRONT SUSPENSION; Front
Closeout Price: $9.77Only 2 Remaining!
- Part No: 0457001
- Notes: Lower; FRONT SUSPENSION; Rear
Closeout Price: $9.77Only 3 Remaining!
- Part No: 530227
- Notes: ABSORBER,FRT SHK FJ80
Closeout Price: $27.79Only 3 Remaining!
- Part No: 530228
- Notes: ABSORBER,RR SHK FJ80
Part Type: Filter
- Part No: FT1185
- Notes: Use until inventory is depleted
Regular Price: $25.79Closeout Price: $13.49SAVE 48%Only 1 Remaining!
- Part No: TS415
Closeout Price: $24.79Only 1 Remaining!
Part Type: Lug Stud
- Part No: BD61173
- Notes: Rear
Regular Price: $1.37Closeout Price: $0.60SAVE 56%
- Manufacturer: BENDIX
- Part No: 142270
- Notes: F Wheel Stud Rht OE STUDS
Closeout Price: $0.67
