Chasing an Oil Leak - opinions please (1 Viewer)
Gundo
Calling on the vast reserves of knowledge here on Mud.
Have also “gotten my search on” and based on results I’ve a strong suspicion of what this is but want to be a bit more sure before moving to next step.
Oil leak at rear of block, coming from the little rubber grommet in the clutch inspection cover.
So, clutch inspection cover off, check
Cleaned and dried main bearing support, check.
Tightened all oil pan gasket bolts (some were finger loose), check
Check those saddle bearing bolts, super tight, check
Wait a couple days, check
Definitely less leakage than before, but still happening.
As an Easter Egg, the Clutch was replaced by PO about 6 months ago. No mention of RMS on any of the pretty thorough paperwork from the clutch repair.
So, oil pan gasket? I don’t have any record of it being replaced. 166,000 miles.
EscapeWagon62
Longmeadow MA
if it was the RMS it would be splaying out all over the engine side of the flywheel
valve cover gasket? push rod cover gasket? both of those can work there way down the rear block and show up in places
I had a leak that looked just like a RMS but turned out to be side cover (push rod inspection plate) gasket.
Also found an oil passage hex screw leak top left where bell housing connects to engine when doing my H55 swap
By far the side cover was the most significant leak
Gundo
Well, it most certainly looks like the push rod cover gasket that is causing the leak - looks pretty gunky in there and around the firewall end of the cover.
Time to dig in and get this cleaned and fixed.
Good news is that I won’t be the first to tackle this and there’s lots of answers on the process here on Mud and elsewhere guys run 2Fs
Here’s a pic as a bonus. The antifreeze was from tonight’s project of refilling and bleeding the coolant after installing my new thermostat. The PO installed a Prestone Flush-n-Fill connector for a garden hose at the high spot just prior to the heater valve - had it open to let air escape and coolant spilled. I guess this is from the time people flushed their radiators down the sewer drain. Doh. I actually had one of these on my ‘73 Torino.
NeverGiveUpYota
Dare me.
East Hampton, CT
That’s so nothing.
OSS
Oblivion
Oil collecting inside the clutch inspection cover and weeping past that rubber grommet is gear oil being flung out past the transmission input shaft and coating the inside of the bellhousing which then oozes down the inside walls and collects at the bottom of the cover - to drip out past that grommet.
If the insides of the bellhousing are slimy w oil, (gear oil) the input shaft seal is leaking.
All cruisers do it eventually- that's why there's a drain hole in the bottom of the inspection cover. No biggie
Gundo
Definitely smells like gear oil. May be a combo deal. Gear oil from input shaft and engine oil from rod cover.
