- Joined
- Jun 17, 2004
- Threads
- 28
- Messages
- 238
So I've been hearing this noise in the drivetrain. It only happens at 50+ mph and when very light throttle or no throttle (coasting or driving down a very flat piece of highway).
I figured I'd start with the front driveline after feeling a tiny bit of play in the u-joints. All four need to be replaced. So I pull the front driveline, lock in the center diff and take off. Noise is gone. Cool. I go to turn around and wanted to see what would happen if I unlocked the center diff.
It drove like normal. Now, this is my first 80 and I was under the impression in high range unlocked diff, it would just send power to the least path of resistance. So, taking a front or rear driveline out would make the vehicle inoperable correct?
Just a puzzling situation.
Oh and my question about the front driveline. There is no play in the slip splines, but I suspect that is the problem and the u-joints are compounding it.
The truck is lifted on J springs. Is that tall enough to warrant a CV driveline? Honestly, the angle doesn't look that extreme. Do any of you have a max degree angle these work best at?
I will start by replacing the u-joints but I was just curious to your experiences. Thanks!
