davidp14
You've definitely got an issue if you're on stock tires .
I get 15 or 16mpgs with 35s and 2.5in lift
Yeah I've got an exhaust leak at the first O2 sensor bung too. Every now and then when it's been sitting for a day in the cold, it stumbles on start up for like 30 seconds. Should I start by replacing the fuel filter, distributor cap, and rotors and see where that gets me?You've definitely got an issue if you're on stock tires .
Yeah I replaced the 2nd O2 sensor like a year ago or so. So ik the 1st one is shot because it was rusted onto the bung studYou might try getting your exhaust fixed first and make sure the O2 sensors are all working.
The worlds most stubborn tie rod end. Been fighting for 3 days now, got the rest of them out, been coating it with copious amounts of deep creep. Any advice? Tried a puller but it broke, tried a pickle fork but it’s not working too well.
Torch on the pitman arm and a puller. Once the puller is good and tight whacking the outside of the arm with a BFH should pop it out. Careful not to heat the rod end or they CAN explode! Or try disassembling the end so if it does get hot the grease has somewhere to expand to.
My problem is that I’ve soaked it in so much Deep Creep (flammable) that I’m afraid everything will catch on fire/explode!
Nah, it’ll burn off fairly quickly. Just keep a fire extinguisher handy, but you’ll be fine. Get the pitman arm glowing.
Actually, now that I’m thinking about it, when I put high steer on my 60 ages ago the ball ripped out of the drag link end. I ended up taking off the pitman arm and throwing it away.
You're saying just to rip that sucker off?
And on my last fill-up, I got 6.776mpg. Which is my lowest ever. So idk what to do
Yeah I did the plugs and wires a year ago, that helped a lot. Probably gonna do the dizzy rotor and cap, and then the fuel filter, also with the air filter and see if that helpsI really would try basic tune up stuff first.
Plugs, fuel filter, air filter, etc. Start with $ and work up to $$$. Then at least you know that the basic stuff is working right if and when you have to replace/repair expensive stuff. (I’ve found that Toyota OEM plugs and wires work great).
Glad things are coming together! Sorry I couldn't hang out more today and help out. Lots of family stuff going on this weekend.Working out vac hoses with @Natev22 today. Got most of these things sorted out. Almost done!
ShenValley100LC said:Ah yes that was me! I remember that!
