- Year
- 1995
- Vehicle Model
- 80 Series
- Location
- United States
$24,000
I have had the truck for seven years and have worked on it the entire time. The list of maintenance items is long and I will probably forget something. The truck will also come with all the parts necessary to do a head gasket replacement when that becomes necessary. This is over 1000$ in parts. I have very extensive maintenance records. The truck is right at 193,XXX Miles
Mechanically the truck is in amazing condition. The passenger front seat does not move forward or back (Bad gears). Third row seats are in great shape and I have them in storage. The drivers side seat has bad, but not terrible wear. It is covered up and protected by the seat covers.
It is time for new front brake pads and an oil change.
The Long:
Old man emu 4” lift with 35” tires on 17” steel rims. The lift was done in 2016 with the tires being installed 2017.
Most recently I had the oil analyzed by Blackstone for a possible head gasket degradation. The report came back with no concerns for any failures.
New Brakes including rotors and SLEE stainless steel extended brake lines.
Coolant system refresh (New radiator, fan clutch, water pump, thermostat, hoses, etc.)
Extended Differential Breather Kit
OPOR Steel Sliders
Custom Roof Rack
Wet Okole Front Seat Covers
Southeast Overland ‘OH No Handles’
Front Axle Rebuild
Tire Rod Ends replaced
4x4 Labs Front Bumper setup for a WARN winch
4x4 Labs Rear Bumper with swing outs, tire carrier, ladder and fuel can basket
Blue Sea Fuse Block installed in center console
Blue Sea USB/12V Ports installed in center console
3D Printed custom cup holders
Weathertech Floormats
Rebuilt Starter
Replaced PCV valve and Grommet
New Spark Plugs & Wires
ARB 8' Awning
You can read through the entire adventure in my signature post.
The Long:
OPOR Steel Sliders
Custom Roof Rack
Front Axle Rebuild
Rebuilt Starter
ARB 8' Awning
