charcoal canister/fuel line help (1 Viewer)
dyersburg, tn
i'm really confused. i have seen conflicting photos of how the lines to a 1977 charcoal canister are connected. Should #1 in the photo be connected to #4? if so, what is #2 connected to?
lastly, should the line in the second photo just end inside a channel underneath the body?
On my truck that runs under the bed to a hard line with a large loop then back under rocker panel to the “to tank” fitting on Charcoal Canister.
My “loop” was toast so I made my own. I thought seriously about deleting it but figured it was there for a reason and can’t stand smell of strong gas fumes in cabin.
Hope this helps!
Yes.
If it says "Purge" then it runs to the base of the carb often through a VCV controlled by your VSV. This is to burn up excess fuel vapors.
If it says "To Tank" it should be also routed under the body to the fuel separator.
Yes.
looks like you found your answer, but here is a thread i used to figure the system out:
