Changing out the Engine, Due to Bad Head Gasket and Other Problems
Pismo, Ca.
Well, right before Christmas I blew the HG on the 80. It also had some noises in the low end, which spurred me to look for another engine. I'll check out the whole engine when I tear it down in the future.
So, I looked at my options and decided to go with a low milage engine from a salvage yard.
I found a semi low milage engine at our local salvage yard. (137k). My plan was to pull the head and visually inspect it and if it looks good simple have the heads serviced and change the HG. I figure it will go for another 100k if all looks good.
So, I picked up the engine and took it to my friends shop. Andy at Advanced Automotive guided me through the process, which probable would have taken me 10x the amount of time it took.
I pulled the head and it looked fairly clean for that many miles, even he was surprised. The HG wasn't blow and the cylinders walls were not scored out. The head shop tested the heads, with no problems, and put the new valve guides in and resurface the head.
The block got degreased and the coolant holes all cleaned out (what a mess) the engine had been siting for 4 months. Next was paint and cleaning the head mating surface.
Now it was starting to look pretty good. I reassembled the head to the engine, carfully following the FSM.
We then pulled the other engine out, what a PITA. It took most of the day. This project is a great motivation to keep my day job.
Now with the two engines side by side we transfered all the components, and changed seals, including the PHH.
Now it's waiting for next weekend to finish up.
Here's picts of the cleaned and assembled engine.
The prepetual LandCruiser....
uh, If I had two motors, and one was tore down to that point:
I would have bought the junk yard motor and rebuilt or rering it then I would have just spent a day (my down time, cause I'd be driving it still on the other) swapping the two...
rebuild the other at your own discretion?
Some more picts:
1) before transfer of components ( silver one blow/ black one new)
2) After ( the used stuff that was questionable was placed back on the blow motor.
3) engine out
Tntoyota, the 80 is,was, a DD and time is of the essence. I figure I can take the blow one and take my time rebuilding it. I'm getting a little tired of driving my trash truck to work. Ha Ha
Before I stabbed to new motor in, speaking as a person suffering from it and the amount of work it takes to fix it, I would change out the upper pan arch seal. No better time than while the motor is out. I would hate to see the arch seal start leaking in a couple of miles. :o
By the way everything is looking good.
Jack
Thanks guys,
locrwin, We changed the front and rear main seals. I'm not sure what the upper arch seal is??
reffug, the price was 1k, which I thought was pretty good after shopping around. Cruisernet wanted 2k +shippping for the same thing. I'm trying to keep this on a tight budget. I'll post up the total after I'm finished.
Pismo,
Great job. Looks like fun.
How's your radiator doing? Now that you have everything out, it would not take too much time and effort to swap it out. Including thermostat and fan clutch.
Just my two cents
Regards
Alvaro
Alvaro, thanks for the resonse. The radiator is 1 yr old, no problems there. New thermostat and I'm putting in the custom fan clutch from Landtank. Hopefully no cooling issues should arrise in the future. Although who knows with the global warming, Kalifornia could be the Calihari (spelling) is a couple years.
BTW thanks to IdahoDoug for the DVD, it's nice to have some back-up picts and video when the manuel doesn't show some spots.
The pan arch is where the aluminum oil pan meets the crank seal holder(both front and rear seals). This is a FIPG seal, and over time seems to break down. It is so much easier to do this when the engine is out, especially if you have a engine stand to hold the engine upside down. But hey it is only about 6 hrs later to do it when it is in the truck and you are laying on your back. You need to remove the steel pan first then the aluminum pan. There are several post on how it do it with the engine still in the truck. Looks like a worth project and you seem to be doing it with conviction. Good luck, Robbie
