Changing gear lube...What Weight?
I'm fixing to change the lube in differentials,transmission,and transfer case on my '78 FJ40. I won't be using synthetics on such a high-mileage vehicle due to leak potential.
Can someone tell me the weight gear lube and capacity PLEASE. ???
Yup, 80W90 used here too :D Get yourself a lube pump while you're at it. They are cheap and make it MUCH easier to get the fluids up in the tranny and tcase. Have fun!!
http://doityourself.com/store/6847610.htm
80W90 here as well, and second the lube pump. this is the job i chipped half my front tooth off in.
can anyone convert gallons and quarts to real measurements (metric)
[quote author=bad_religion_au link=board=1;threadid=5059;start=msg38932#msg38932 date=1063034214]
[/quote]
Here's a great link to keep handy for conversions:
http://www.onlineconversion.com/
there is a fill plug on everything...when fluid drips out of the plug hole, it's full. If you have a rotated front/rear axle (SOA or something) then a couple extra "plunges" on the pump will overfill it enuf to keep the pinions lubed.
I've yet to measure...lol
So 80w90 it is! Thanks again. :banana: :banana: :banana:
My Manual printed in 1986 says SAE90 for the Diffs, Transfercase, Gearbox and Steering Box. ::)
I currently have Valvoline Hypoid 85W/140 in the Diffs, Transfercase and Gearbox, And Valvoline LS90 in the Steering Box.
Previously had Mobil 80W/90 in the gearbox and I could feel and hear the Syncros have a huge whinge every time I placed it into gear. >:( With the Valvoline Hypoid 85W/140 it's so smooth and no clunking Noises. :)
