Changed Out Drivers Seatbelt got airbag light
Boone, IA
'99 TLC Changed the drivers seatbelt yesterday now I have a slowly flashing airbag light on my dash. I unplugged the battery for a few hours it when away yesterday but started this morning to a slowly flashing airbag light. Any help here would be appriciated.
Most likely the new seatbelt is bad. They have a charge in them to retract the belt if the airbag is triggered.
You can pull the code with an appropriate obd reader, and there is also a way to get it to flash a code in the manual by connecting pins in the engine bay port. Odds are though … You could plug in your old belt and see if it clears.
Not sure if it is bad I pulled it from my old '99 TLC and everything works on it (except the frame that is rusted through in many locations) but I will check for a code.
You really need to use Techstream to read the code(s). We ran into this on my son’s vehicle, and if I remember correctly, more generic code readers (Scangauge & iCarsoft) reported “no error codes”, while Techstream picked it up immediately.
Yeah, that's what I meant by "appropriate." I have te Toyota modules for OBD Fusion and can read the airbag codes.
Okay so I haven't read codes but now the light is off again. Last night it did the same thing so I don't know what to do now.
