When I lock the center differential it will not disengage when I depress the switch to return to normal operating mode.
I am not sure if it is a faulty switch or if I am engaging and disengaging the differential improperly.
It eventually disengages when I put gear lever in Drive and creep forward.
Can someone explain the proper procedure for engaging and disengaging the differential?
The owners manual does a poor job of describing it use.
