Center diff switch on 4H
Lafayette, La
I bought a new center diff switch on my '95 80 and when I plugged it in it was on center diff lock. I clicked the switch a few times, drove it around and it never has disengaged. tried the backing up trick and nothing. I do have factory lockers and not sure that the problem is. I exercised the lockers a few weeks back at SCC and everything worked as intended. Not sure what's wrong.
You said you're in 4H? you need to do the pin7 mod for the switch to work in 4H.
Pin 7 mod should not be required for using in 4H, it’s so you can toggle the CDL in 4L which normally keeps it locked. My switch works perfectly for 4H, haven’t done pin 7 mod yet.
Pin 7 is to be able to run in 4LO without the cdl locked. The cdl switch lets you engage the center locker in high gear. Not sure why it won't disengage or turn off. I think I remember having something like that happen to me when I first installed mine. Try turning off the switch and turn off the vehicle and then start her up again. Maybe try engaging the CDL with the transfer case moved to 4lo and then dissengage it. Did you try actually moving the vehicle to see if the CDL is actually locked?
I did and it is. I did disconnect the switch and put the jumper back and it did unlock, but if I plug the switch in, it automatically engages cdl. Tried driving around, pushing the button, going 4lo, back to neutral. Stays locked
