CDL switch relocation tips
Discussion in '80-Series Tech' started by new2mud, Jul 25, 2005.
  1. new2mud
    new2mud
    89
    May 5, 2004
    For those who want to put the CDL switch over on the driver's left side (next to the dimming dial), it's really easy to do:
    The lowest panel under the steering wheel pops out after removing 3 screws.
    Then the panel that contains the "switch box" that has the dimmer and the blanking plates removes as an entire unit (this panel runs all the way across the top of the steering wheel and contains the hole for the ignition key)--do NOT try to remove just the little black switch panel).
    This upper panel just pops off at 3 points (just give it a good tug as you work your way left-to-right) and it will pop right out.
    Note: this way you do not need to try to pry out the blanking plate from the front and risk marring the surrounding plastic--you will be able to pop out the blanking plate from behind after you remove this upper panel.
    At this point you have easy access to use stout wire or coat hanger to run the 5 needed extension wires from the above-the-radio location of the original CDL harness to the new switch plate on the driver's left.
    Snip the CDL harness, solder your wire extensions in, and you're ready to go!
    Thanks to Rob for the relocation idea!
  2. LCL
    LCL
    42
    Nov 7, 2004
    Orinda, NorCal
    I am a very visual based learner. Pictures would be greatly appreciated!
  3. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    SNIP??? SOLDER??? :eek:
    I'll just plug mine in on the other side...thank you :)
    Thanks for the write up though, I need this info for my light switch install.
  4. 97 FZJ80
    97 FZJ80
    1,539
    Albums:
    1
    9
    Jun 3, 2003
    Plano Texas
    I had to cut away a few wire ties to get the CDL switch to mount on the lower siwtch position - next to the rear heater switch. Was your LX CDL wires long enough to reach to the other side of the steering wheel? :confused:
  5. NorCalDoug
    6,294
    120
    Oct 27, 2003
    Mine? No. I just did what most others do...
    I moved my alarm sensor/light to one of the lower spots and installed the CDL on the top row next to the Hazard button.
    I would've preferred it to be tucked away, but didn't want to mess with the wiring (i.e. cutting, soldering, etc.) The less soldering the better for me -- I solder like a tard ;)
  6. new2mud
    new2mud
    89
    May 5, 2004
    No, definitely the stock harness is not long enough to reach to the left of the steering wheel. I soldered in wire extensions to reach. I didn't want to relocate any of the existing switches, and also wanted to have the switch away from any passenger's inadvertent reach (including kids!).
    Some have noted that they haven't had any problems with accidental CDL button presses in the above-the-radio location, but I just don't want to take any chances.
  7. NorCalDoug
    6,294
    120
    Oct 27, 2003
    Agreed. Great idea. If I had soldering skillz, I would've done the same.
  8. mabrodis
    mabrodis
    1,151
    6
    Mar 22, 2004
    Castle Rock, CO
    Cool to have options of where you can put the switch, I just put the CDL switch in the normal place when I had my LX, for me I hated having anything to the left. When I drive my left hand is always on the steering wheel, right hand is for shifting, eating, pointing, throwing rocks, etc...so for me having to control something on the left side of the steering wheel was a pain. I hated having the locker switch over there too, and on my next vehicle I will put some effort into seeing how hard it would be to move that switch to someplace more convenient for me...probably won't be able to move it, but I'm not a fan of switches over there...just my opinion...
  9. new2mud
    new2mud
    89
    May 5, 2004
    OK, here's my attempt at graphical tutorial:
    I had to modify Rob's picture, which is the only picture I had of the interior.
    Keep in mind that the panels actually extend all the way across the steering wheel to the right (as mentioned, the upper panel contains the cutout hole for the ignition key--you can't miss it!)
    Just don't try to pop out the black button panel--it is a single unit with the upper panel (as far as I know).
    Again, thanks to Rob for the picture (hacked drawings and text are mine--sorry!) and the tips!
  10. 97 FZJ80
    97 FZJ80
    1,539
    Albums:
    1
    9
    Jun 3, 2003
    Plano Texas
    Do you :flipoff2: with you right hand? :D
    The reason to have the CDL on the left of the steering wheel is to have it next to the diff lock switch and out of the reach of other passengers.
  11. OZCAL
    OZCAL
    1,216
    3
    Nov 16, 2004
    Queensland and California
    Thanks for this. I'l be doing it soon.
    David
  12. new2mud
    new2mud
    89
    May 5, 2004
    Clarification: on the drawing it looks like it says to not remove the CDL switch panel by itself--while true, I intended for it to state not to remove the larger black panel that houses all the switch blanks and the dimmer knob--as far as I know, it is a single unit with the entire upper panel.
