CDL and ABS light turns off on reverse?
Eastvale, CA 92880
Hi! I did the CDL switch mod with a tercel hazard switch. Switch is working well, both cdl and abs light turns on when i press the switch. However, when I shift to reverse, both CDL and ABS light goes away? Is this normal? I am doing this mod because I will be removing my front driveshaft while I sort my driveline noise problem. What I am worrying about is, without my front DS, while on reverse without the CDL engaged, would it actually go reverse? Would it spin on the side that does not have the shaft because technically it has no traction. I dont know if I am making sense here. Please enlighten me. Thanks.
